Detect Adblock script HELP - HTML CSS JS
hyiee Lengends!!
recently i had applied detect-adblock script in my site! which was worked !
the problem is its working well in DESKTOP(chrome with ublock) and detected the adblock also!
but when i try to view in mobile(FireFox with uBlock addon ) it won’t detect
So if anybody know coding please help me to solve the issue!!
HTML CODE
<div id="detect"></div>
  <div class="wrapper">
    <div class="content">
      <div class="warn-icon">
        <span class="icon"><i class="fas fa-exclamation"></i></span>
      </div>
      <h2>AdBlock Detected!</h2>
      <p>Our website is made possible by displaying ads to our visitors. Please supporting us by whitelisting our website.</p>
      <div class="btn">
        <div class="bg-layer"></div>
        <button>Okay, I'll Whitelist</button>
      </div>
    </div>
Css
    @import url('https://fonts.googleapis.com/css2?family=Noto+Sans:wght@700&family=Poppins:wght@400;500;600&display=swap');
  margin: 0;
  padding: 0;
  box-sizing: border-box;
  font-family: "Poppins", sans-serif;
body{
  width: 100%;
  height: 100vh;
  background: linear-gradient(135deg, #9b27ca 0%, #9927cf 0%, #d33639 100%, #f92121 100%);
::selection{
  color: #fff;
  background: #9b27ca;
.wrapper{
  position: absolute;
  max-width: 480px;
  top: 50%;
  left: 50%;
  width: 100%;
  padding: 40px 30px;
  background: #fff;
  border-radius: 15px;
  opacity: 0;
  pointer-events: none;
  transform: translate(-50%, -50%) scale(1.2);
  box-shadow: 10px 10px 15px rgba(0,0,0,0.06);
  transition: opacity 0.2s 0s ease-in-out,
              transform 0.2s 0s ease-in-out;
.wrapper.show{
  opacity: 1;
  pointer-events: auto;
  transform:translate(-50%, -50%) scale(1);
.wrapper .content,
.content .warn-icon,
.warn-icon .icon{
  display: flex;
  align-items: center;
  justify-content: center;
.wrapper .content{
  flex-direction: column;
.content .warn-icon{
  height: 115px;
  width: 115px;
  border-radius: 50%;
  background: linear-gradient(#9b27ca 0%, #9927cf 0%, #d33639 100%, #f92121 100%);
.warn-icon .icon{
  height: 100px;
  width: 100px;
  background: #fff;
  border-radius: inherit;
.warn-icon .icon i{
  background-clip: text;
  -webkit-background-clip: text;
  -webkit-text-fill-color: transparent;
  font-size: 50px;
.content h2{
  margin-top: 35px;
  font-size: 32px;
.content p{
  font-size: 19px;
  text-align: center;
  margin-top: 20px;
.btn{
  height: 57px;
  width: 223px;
  margin-top: 30px;
  border-radius: 50px;
  position: relative;
  overflow: hidden;
.btn .bg-layer{
  height: 100%;
  width: 300%;
  position: absolute;
  left: -100%;
  background: -webkit-linear-gradient(135deg, #9b27ca, #d33639, #9b27ca, #d33639);
  transition: all 0.4s ease;
.btn:hover .bg-layer{
  left: 0;
.content button{
  position: relative;
  z-index: 1;
  height: 100%;
  width: 100%;
  background: none;
  font-size: 18px;
  border: none;
  outline: none;
  color: #fff;
  cursor: pointer;
How are you detecting the adblocker? Are you using a pre-made script, or something you made yourself?
Thanks.
Already I mentioned the code which used for detect adlock above! Have you not seen??
See the image which is having html page!
The same page not working in mobile!
For your reference!
  <scrt>
    const detect = document.querySelector("#detect");
    const wrapper = document.querySelector(".wrapper");
    const button = wrapper.querySelector("button");
    let adClasses = ["ad", "ads", "adsbox", "doubleclick", "ad-placement", "ad-placeholder", "adbadge", "BannerAd"];
    for(let item of adClasses){
      detect.classList.add(item);
    let getProperty = window.getComputedStyle(detect).getPropertyValue("display");
    if(!wrapper.classList.contains("show")){
      getProperty == "none" ? wrapper.classList.add("show") : wrapper.classList.remove("show");
    button.addEventListener("click", ()=>{
  </scpt>
Misspelled script I know!
I was asking if you made this yourself or if you got it from somewhere. I saw the code.
I’m searching over internet and used that!
If I have the capability to write the code ! Then y I have to ask here!
Just got from internet only!
No need to be mad at @Greenreader9 when you create a topic we can reply with questions so we can answer your question, we don’t really come across questions that require code, you should probably ask in Stackoverflow, because they specialize in code.
I know bro!
But if any minor mistk na!
As per Experience people can help us know!
I’ve never really implemented a “detect adblock script” because I don’t use ads there are a lot of scripts in the web, and if they don’t work try asking in Stackoverflow. Although what I have noticed is that querySelector isn’t the best for ids so you should probably use document.getElementById()
Okie bro!! Thankz for ur advice!
