Has anyone everwhen I export the database the following messages appear:3
SET SQL_MODE=“NO_AUTO_VALUE_ON_ZERO”;
SET time_zone = “+00:00”;
/*!40101 SET @OLD_CHARACTER_SET_CLIENT=@@CHARACTER_SET_CLIENT /;
/!40101 SET @OLD_CHARACTER_SET_RESULTS=@@CHARACTER_SET_RESULTS /;
/!40101 SET @OLD_COLLATION_CONNECTION=@@COLLATION_CONNECTION /;
/!40101 SET NAMES utf8 */;
CREATE TABLE IF NOT EXISTS wp03_as_keywords_cron (
keyword_cron_id bigint(20) unsigned NOT NULL AUTO_INCREMENT,
keyword_id int(11) NOT NULL,
number_of_posts tinyint(4) NOT NULL,
execute_next int(11) NOT NULL,
UNIQUE KEY keyword_cron_id (keyword_cron_id)
) ENGINE=MyISAM DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci AUTO_INCREMENT=1 ;
What should I do? It happened after the sites were gone. Can someone help me? had this problem and how did it resolve?
