Access denied for user ‘epiz_27834217’@‘192.168.2.194’ (using password: YES)
I made a connection using the host name, username, and password to my databases. In localhost it worked well but here I am getting error message Access denied for user ‘epiz_********’@‘192.168.2.194’ (using password: YES) what could be the exact problem. The password is correct, the username is correct, host name is also correct. Please help am new to web development please share the FULL error message
They did match. Only that I didn’t include the database name in my config script intentending to do when I need a specific databases to use using the sqli_select_db
heh im just off to learn mysql so I can understand that
btw if you highlight your code in the message editor and then click the preformatted text icon in the message editor top bar it’ll display nicely like this
