Daily MySQL outage at 12:00 sharp — SQLSTATE[HY000] [2002] Connection refused
https://el-wassim.page.gd
SQLSTATE[HY000] [2002] Connection refused on any query (e.g. select * from admin_users where id = 2 limit 1), every day around 12:00 server time, for about one minute, then recovers by itself. Seen on 11, 12, 14, 15 and 16/10/2026 (e.g. 16/10 12:00:21). DB host: sql102.infinityfree.com.
Credentials are unchanged and correct (works immediately before and after). This is not a max_user_connections (1226) error and we use no persistent connections — the TCP connection itself is refused, which points to the DB server being briefly unreachable/restarting rather than our code. Is there a daily maintenance/restart window on this DB server around 12:00? Other accounts on the same server seeing this?
Thanks!
I can’t find anything on the forum or in the knowledge base about a daily restart or maintenance window on sql102 around 12:00. So I can’t confirm or rule out that this is the DB server, and I won’t guess.
You’ve ruled out the usual suspects well: correct credentials, not a 1226, and no persistent connections. Whatever is behind a one-minute refusal at the same time every day is on the server side. That means a person on our staff needs to look at sql102, and nothing you can change in your code will fix it.
One detail would help whoever looks: the exact time of day, with timezone, for a few of those failures. A single error that shows a clear pattern helps more than a general description. Please also say whether phpMyAdmin or other sites on the same account fail at the same moment. If phpMyAdmin fails too, that would point even more strongly at the server.
Thanks for checking. Timezone details:
  • All timestamps are Africa/Algiers (UTC+1, no DST). So the window is 12:00 local = 11:00 UTC daily.
  • Exact spans: 11/10 12:00:31→12:00:57, 12/10 12:00:06→12:00:56, 14/10 12:00:49→12:00:50, 15/10 12:00:49 (×2), 16/10 12:00:21 (×2). Always ~60 s max, full recovery after.
  • I will test phpMyAdmin + a second site on the same account during the next window (tomorrow ~11:59–12:01 local) and report whether they fail simultaneously.
This is the first time I’ve heard about this, and I’m surprised that you were able to measure this.
Based on what I see checking the MySQL status information, it seems that the MySQL server is restarted automatically every day at the same time. Given the timing, this must be something intentional, like an update or a cleanup operation. Unfortunately, I don’t know the exact details.
Please be aware that keeping server software up to date is critical for security, and that restarting a process regularly is necessary to make that happen, so obtaining 100% uptime is impossible if you also want to keep a system secure.
I wouldn’t worry too much about this. Even a minute of downtime per day puts you well above 99.9% uptime, which is very respectable for any hosting service.
