CURL error 60: SSL certificate problem
https://techtapole.rf.gd/
Error: cURL error 60: SSL certificate problem: unable to get local issuer certificate.
Hi
i am having this error when iam trying to connect an extension of a plugin to woocommerce, that want to authenticate the domain, is it a cummon error ?
somebody may have a solution ?
Cheers
Did you try searching the forum to see if there are more people with similar issues?
spoilers: there are
Somebody may indeed, but I’m not sure. I know of (but have never used) WooCommerce, but I don’t know what “extension of a plugin to woocommerce” you are talking about, what it should so, or why it would show that error.
However, if the specific integration you’re looking for requires some external service to connect back to your website, then note that this may not be possible due to this security system: Ensuring only web browsers can access your website
Thanks for the clarification,
i also don’t know the technical side of what that extension want to do, basically its an add on of the plugin : ALD - Dropshipping and Fulfillment for AliExpress that is supposed to work when i am browsing on aliexpress, show insights and import product from the site
is the error from their side or from here ?
I don’t know much about Woo either (I used it once about 4 years ago for a very brief time), but the text on that button makes me think of this:
