cURL error 60: SSL certificate problem: unable to get local issuer certificate
Include your domain
Website not complete yet mctoolbox.ga
Any solution?
Let me check.
curl method? get or post?
Jetpack plugin when i was connecting my wordpress.com account
After trying by php it returns JavaScript disabled page
The possible reason that I think is your GoGetSSL ssl certificate, may this certificate not trusted by Jetpack plugin (I am not sure).
I will suggest you two possible solution
  • Test with letsencrypt ssl
  • Use Cloudflare (free SSL from Cloudflare)
Otherwise: Post this issue in wordpress support forums, hopefully plugin experts will help you
I also have a website with different ssl provider and have the same prob
I think you should post this issue in wordpress support forum
There are plenty of other topics on this issue so please search the forum before creating a topic; a couple solutions are below.
You can force Jetpack to communicate via HTTP only, by adding this constant to your site’s wp-config.php file:
define( 'JETPACK_CLIENT__HTTPS', 'NEVER' );
Or as others have said, try using a different certificate.
Already solve i remove the plugin cause its not compatible with my security plugin.
Just use wordfence it’s more easier to use
