It’s okay, that happen to me always.
Question:
Did you already registered your .com domain to Cloudfare right?
Question:
yes I had it setup and fewcharecorsd.com was working with padlock over ssl.
then I tried to transfer wordpress site to the same locaton and thats where i am now:)
I have probably done things in the wrong order and it (me) is getting confused ![]()
Reinstalling now
ok reinstalled and I now have a blank wordpress blog showing on my domain and still have a padlock.
Next step is to try get my site imported back into word press?
Yes, exactly!
Its a ‘fresh installation’ template. Import now your backup photos/site.
I would if wp-admin worked ![]()
page cannot be displayed when trying to customize or go into https://fewcharecords.com/wp-admin/
hmmmmmmmm
Do not use Full mode in Cloudflare Dashboard.
Set it to Flexible and enable Always Use HTTPS and Always rewrite HTTP then clear your browser caches or try to logging-in to wp-admin using incognito mode if you don’t want to clear your browsing data.
yep still set to flex and use https
That won’t happen if you set it to Flexible Mode. Please check it again?
shouldn’t this have https://www.fewcharecords.com ?
May I see your DNS config on your cloudflare dashboard? just hide the ip address of your domain cause all I can get is an HTTP ERROR 508.
pic taken down for now
Try enabling the Full mode or Full (Strict) instead of Flexible.
both options then give this error for fewcharecords.com - before wp-admin it fails
I never heard this kind of problem before here in Infinityfree ![]()
I still see your error SSL HandShake Failed.
I also see the “Too many redirect” error.
not sure whats happening here myself.
i am removing wordpress again and trying with protocol https://www.
before I only tried https://
If this fails, I might look at how to put everything back to default so I can start again, if possible.
Try disabling the Automatic HTTPS Rewrites & Always Use HTTPS and set again to Flexible.
This will remove the https and will not force the visitors to redirect to https when visiting your site, but we have a guide for you after you will managed to login into your wp dashboard.
It might not still work if you don’t redirect your visitors to your www domain.
Cause it will only install WordPress to www.fewcharecords.com, and if the visitors visited the fewcharecords.com only and not with www.fewcharecords.com, the WordPress resources will not work/load and they must visit the-with www in order to load the resources.
But you managed it XD!
You can just download Wordpress manually to avoid http/https/www/ errors.
First: download the latest wordpress zip file. Here: Download – WordPress.org
Second: Upload and extract these on your file manager. Wait until done.
Third: Open your website, you see an installation page. Follow the instructions that Wordpress installation given.
Done! May this help you!
