Username: epiz_26634200
http://listen-together.epizy.com/
I try to setup two CRON jobs but they both seem not to be executed. I am quite sure that they are working fine, because when I manually run the php scripts by entering the URL in my browser they do what they are supposed to do.
What have you set the time interval to on the Cron Jobs?
One on 2 minutes and the others one on 1 hour.
Set your first one to 1 hour and 2 minutes
Setting the first one to 1 hour and 2 minutes results in the cron being executed every two minutes. So thats fine.
But what shell I set the other one to. I want it to be executed every several hours. Setting only the hour to 1 does not work.
Set the hours to the amount of hours you want and the minutes 2, the Cron Jobs tend not to work when one of the sections is blank.
system
Closed
September 19, 2020, 8:31pm
8
