Critical website error Tried both ways direct and manual installation
my website is this
i have been facing
THERE HAS BEEN A CRITICAL ERROR ON YOUR WEBSITE.
firstly i tried installing woocommerce pluging directly and it failed.
Then I tried installing it ( woocommerce Plugin ) manually it got installed but it failed while activating.
after activating the website crashes and shows :
similar issue occur while installing some other plugins & theme
please help!
Try to install the plugin manually via FTP. The instructions to do that are here.
done no use same issue
Was your website already showing errors before attempting the manual plugin installation? Because if so, you should try to remove the broken plugins and themes first before attempting a manual installation. A manual installation on a working site should not fail like this.
@anon21121822 first thing to do is deactivate some plugins, try activating woocommerce again, then repeat this process until you find the plugin(s) causing woocommerce to fail.
If your site was showing errors before the woocommerce failure you’ll need to fix that first. You could use the same process, remove themes and plugins, then start activating them one at a time until you see errors to find the broken/corrupt plugin or theme.
