Create and account using only a custom domain
Can i no longer create and account using only a custom domain from the start?
@Riconico I moved your screenshot here and please stop writing in that “old” topic.
Hi and welcome to the forum
Check the home directory of your domain
In the Domains page of your account in the client area, you can find the domains of your account and the folders on your account they are linked to.
Please make sure that the domain folder listed there actually exists on your account (every URL will redirect to a 404 page if the domain’s website folder is missing), and that you uploaded your website files to that directory.
Yes, that’s correct, creating accounts with custom domains is no longer supported. You’ll need to create an account with a subdomain first, and add the custom domain after. But you can immediately remove the subdomain after creation, if you want.
