Cpanel not working
My website URL is:shreejalmaharjan.ml
What I’m seeing is: I’m stuck at loading screen of app.infinityfree.net
when I press on control panel, it redirects but doesn't load.
I’m trying to use Cpanel. It shows this error
Is it only for me or y’all having this problem too?
The control panel is loading fine from here. Can you please check if you get the same error on other devices or network connections (like a VPN), so you can rule out any issues with your own internet connections?
