Cpanel Disc storage Problem!
I have used one backup plugin to backup my site but it stucked at middle. After that i went to file manager and i deleted that plugin folder. After that inside file manager the storage is accurate (1.3 GB) but when i looked at cpanel dashboard is shows 3935 MB used. Kindly assist me how to bring back that storage to 1.3 GB?
Just wait. The info should update itself in another 8 - 10 hours
Do you actually know what does that “1.3 GB” means?
It does not mean you have 1.3 GB worth of file on your account. It means that you can upload a maximum of 1.3 GB through file manager.
The control panel is probably correct.
