I hope theres someone out there that knows photoshop 7 and can help me with this
what im trying to do is to load my image.png into photoshop 7 (the image is on a layer not on background) and give it rounded transparent corners. basically trying to remove the square corners from the image
ive been googling this for a while but I just havent been able to find a solution
The other answers lead me to believe that I might have read between the lines a bit too much and therefore misunderstood the question. Just in case I didn’t, here’s my answer.
Before I explain the process, here’s an example of what I think you want…
Things do get a bit complicated when you wish to export different size images with rounded corners.
I would perhaps do that with the help of Channels, Gaussian blur and Levels:
Open one of the files you wish to give rounded corners.
Start recording a new action.
Select all Ctrl + A.
Top menu: Select > Modify > Border.... Width: 1 pixels.
In the Channels panel, click Save selection as channel icon (Looks the same as Layer mask icon in Layers panel).
If there’s a chance that your image documents already contain channel Alpha 1, you might wanna click that icon while pressing Alt and give it a distinct name. That way you don’t accidentally take a selection from a wrong channel later on.
Click on the channel you just made, to select and reveal it.
Deselect Ctrl + D.
Top Menu: Filter > Blur > Gaussian blur.... Try to make the blur radius visually the size you want your rounded corner to be.
Levels are used to make that blurry rectangle into a crisp rounded rectangle Ctrl + L.
This requires a bit more explanation:
You’ll definitely want to zoom in for these steps so that you can hone in the sharpness of the edge.
First move the black arrow as far to the right as it takes for the sides of the blurred rectangle to reach the edges of your document. ( …or you can also leave some padding for like a Drop shadow or something. )
Then move the white arrow to the left so that all of the arrows are overlapping.
and everything that is in the appropriate container or say has an img tag
it will be rounded (while the original image below is of course a quadrangle)
