Not Found
The requested URL /panel/modules/signout/index.php was not found on this server.
I created 3 of the 3 possible accounts. First one works fine still but second pretty much immediately started to show this error message whenever I tried to access CONTROL PANEL. Therefor I created a new account that worked fine until right now and now always shows the same error. Does not depend on the device and has to be server related since account 1 still works fine and the issue persists on different devices…
Searched the web and it seems that this issue appeared several times already but never with a proper solution
Interestingly, when I access https://cpanel.epizy.com/panel directly, it is working… There must be an issue with the connection or login process via ininityfree… I mean it is a workaround to access it that way but it is still annoying
Oh yes, I too face this problem, but it happens on a random basis. I just clear my cache every time this happens to me . But still the issue needs to be taken care of.
clearing the cache does not work for me. Even not able to upgrade the account because once I enter the plan and domain I would like to use the same problem appears… Really makes me wonder if I should consider buying a pro plan at all if this is so buggy
