Can anyone give solution for it,coz before at least it loaded with multiple refreshes but now stuck with the magical circle of Loading.
Weird, i have no issue, and there are no solution.
IDK what to do(tried in 4g/5g and checked in my frnd’s network also)
Try using cpanel.rf.gd
That works fine for me but cpanel.epizy.com gives error
The control panel has some VERY stupid Javascript code where they decided to “optimize” the simple links and icons in the control panel main page with tens of thousands of lines of Javascript code. Because apparently showing a loading animation for multiple seconds is better than waiting for HTML code to be loaded in.
Some custom code in the control panel was changed recently which may have caused this issue. I’m going to investigate this and see if it can be improved.
EDIT: The custom code has been changed now so it should load a bit more efficiently. Due to caching and the like, it can still take a while for everything to work though.
Hey don’t worry about that just follow my tips because I’m also facing this problem too
If you are seeing loading animation continuously then click on
Infinityfree logo
Then wait till the page loads, and Done!!!
Note:- this is my personal working suggestion
