Connection timed out Error code 522 - cloudfare
https://comimc.com.ar
CLOUDFARE Connection timed out Error code 522
WHEN I ENTER THE WEBSITE FROM MY IP, IT WORKS WELL, BUT OTHER USERS, OR ME USING A VPN, CANT GET IN.
Image (sorry for putting everything in the same image, but the forum doesnt let me add more)
Welcome!
For starters, you can remove those NS records. The DNS NS record is different from a nameserver. As long as the domain is connected to your InfinityFree account (which it appears to be), you should be fine.
Additionally, you can remove all of the CNAME records that point to BODIS. You don’t need those.
Since you blacked out the IP, please make sure that the IP in Cloudflare is 185.27.134.151.
After doing all of that, purge CloudFlares cache, then retry. If it still does not work, please send a new screenshot of the CloudFlare DNS panel.
Thanks!
