So im planning to make it on the game BlackNova traders and im worried if i even clicked a button there ill get suspended. suggestions?
Make what?
Can you explain a little further?
Suspension details can be found in support.infinityfree.net under the “fair usage” header.
Thanks.
imma try to explain better
basically im planning to host a game on my newly registered domain, blacknova.rf.gd.
now under softaculous apps you can install games on the domain but the thing is idk if a few players or something kills the account and gets it suspended… again
oh and imma wait 20 mins for the softaculous to start working
why again?
[CLASSIFIED]
It should work. As long as your game is not abusive, I see no reason why you should not try. If you get suspended, than you know it won’t work.
i have a problem can u help me out i cant open softaculous apps installer it says something went wrong please wait 20 mins and retry but it has been more
When was your account created? It can take a few minutes for your account to be completely set-up. Just wait a few minutes and try again.
made it like an hour ago
I would check every half hour and let me know if it happens again tomorrow.
ok
whatever ill just deactivate that hosting account and get a blacknova.ml freenom domain just cause i didnt find anything on the internet and on my other website everything is fine
Infinityfree does not support hosting games, mainly multiplayer ones.
Try using replit for that.
I agree with Thewebuser22 with hosting stuff on repl.it since repl supports lots of programming languages.
Blacknova Traders didn’t work for me anyways so it might not work for you unless you change some of the code if you know how to.
I don’t see any reason why this would cause any issues. If you have a lot of active players, that could become an issue, but in general it should be fine.
That said, PHP web games are not seen so often anymore, so I don’t know how many people use it and what their experience is.
Go is prob much better, due to its ease of use yet high performance.
That said, NodeJS has much more support, especially with the physics engines and frameworks ThreeJS that will help you make a game much easier.
