https://docs.newenglandersdiscord.rf.gd
The CNAME record for this hostname is not pointing to 1830f5a661-hosting.gitbook.io or the update has not yet propagated
N/A
N/A
Hi and welcome to the forum! I checked and the record is propagated on my side; you might need to wait up to 24 hours before you check it on Gitbook again to see if it’ll then load up.
Okay, and thank u for the fast response; just so you know for some reason its working now its active and live
