Hi, i have a subdomain example.epizy.com and i want to add it a CNAME record to connect google to it
But what i need to enter the SOURCE field?
Maybe www? Possibly @ (it doesn’t work)? Or possibly i need to keep empty?
I have to add a CNAME record
Connect to google for what? Can you share the image of the record you are supposed to add?
I need to connect it to google sites
to www to ghs.googlehosted.com
Illegal to do that here, read more:
Ok
No problem, it is allowed using custom domains?
You can use Cloudflare for that purpose.
Nice
Feel free to mark any reply as the ANSWER!
