Hi,
It has been more than 4 days that I have added an CName Record and I have checked it that it is put to the right domain and the right record name and destination.
The record was added for ssl certificate.
But up till now the CName Record is not activated.
@Divyaansh, I need to see the actual CNAME entries (the CNAME that you copied and pasted). Please screenshot the entire screen, and make sure the entire page of the control panel is visible.
Thanks
As you can see in the screenshot, it says chatmeet twice in the control panel, but in the client area it says chatmeet only once for each domain. So it would seem you did add a CNAME record, but not with the right name.
Please make sure to select the right domain name from the Domain list when adding a CNAME record.
