Hi!
usr: epiz_25935447
www: charco.live
ISSUE ABOUT CNAME update for ssl cert verify
After changing it on control panel have check for 3 days already and
no CNAME RECORDS - need to update for SSL cert
needs to be
_C86DC0B5697CDF87B9575A5763F7E46C.charco.live
pointing to
11FB71C423F22BCD6E769647A9A71A6F.CD1E5EB6B22C209570E25A10D2C33854.ea363da9e08c6e6.comodoca.com
check cpanel config:
thank you in advance
Admin
June 6, 2020, 9:26am
2
The CNAME records looks fine:
What makes you think they are not?
Also, if you want free SSL, you can also use our free SSL Certificates tool. And if you don’t like our tool for some reason, would you mind sharing your feedback?
Half a year ago, we released our own SSL Certificates tool. The purpose of this tool was to make it easier to get free SSL certificates on free hosting, by using CNAME verification as a way which works more reliably than HTTP or TXT verification (which typically involves external tools to get to work at all).
Since then, many thousands of certificates have been requested and installed successfully!
However, I also see that plenty of people purposely choose to use Cloudflare to get HTTPS, or ge…
