CNAME not found
hi i change the cname of my website to have the ssl in my page, but i click refresh dns status one day ago and never show verified o success, i need help to add ssl my page.
Hello there,
Did you refresh DNS status again today?
Also what’s your domain so we can lookup your CNAME records. Also can you provide a screenshot of your CNAME configuration?
yes i did refresh the dnd to day bro.
So what’s your domain?
Also can you provide a screenshot of how you configured your CNAME records in the Control Panel?
my domain is giklab.ml
i have the ssl but i install the wordpress and say https not found in your website and i think so this the problem…
I looked up your CNAME records and it doesn’t seem like you add the CNAME records on the Control Panel.
Can you provide a screenshot on how you configured your CNAME records in the Control Panel(cpanel.epizy.com)?
OK it seems like you just added a screenshot to your last reply.
i copy the code of cname
im goin to cpanel dns record
and paste or register the cname in my cpanel, im wait one day and nothing :confused:
I checked your nameservers and it seems like you are using Cloudflare.
Then you’ll have to edit your DNS records by going to the Cloudflare Dashboard directly.
Hi bro i delete the web site yesterday
and i modified the nameserver in freenom have the dns of cloudflare and use to infinityfree ns1.byet.org, i have to waiting again. for get the dns again. sorry for my bad english bro…
mmmmm i modified the dns, delete the domain in cloudflare in freenom but i have again the ssl in infinityfree, because i cant use the cname :/, how i can start again with my domain?
I’m confused about what you are trying to say.
Your problem was easy to solve if you didn’t delete your domain on cloudflare before.
You were only supposed to add the CNAME records that the Client Area has given you directly to Cloudflare to get your SSL certificate.
See this:
There you can add the correct CNAME records to get your SSL if you are still using Cloudflare and their nameservers.
Also it seems like you already have an SSL certificate for your site.
Why do you need another one to be issued on the Client Area?
