What I’m seeing is: When I try and upload a cloudflare ssl certificate, it does not accept it and it gives me the message:“The certificate uploaded is NOT for the domain name trumpetfingerings.com (CloudFlare Origin Certificate was seen)”
I’m using this software: infinity free web hosting with namesilo domain registrar.
Cloudflare’s Origin Certificates are not valid certificates. Cloudflare is not a recognized SSL vendor, so their “Origin Certificates” cannot be uploaded. To use Cloudflare on your site, you can configure Cloudflare to use “Full” SSL mode in conjunction with the default certificate, which also ensures your connection is encrypted the whole way. If you insist on using “Full (strict)” mode, you must use a regular SSL certificate for your site instead.
