I shifted my domain to cloudflare tomorrow because I needed to add txt records. It was working all good tomorrow, but today, my domain is not working anymore. What’s the reason?
My domain is ptclab.gq.
Very vague. This is what I see.
You may read this
If you have a http to https redirect in .htaccess, remove that for a start
It worked. Thank you @KangJL
But it now don’t redirect http to https. But I need http to https.
Use a plugin? Maybe “Really Simple SSL”?
Use CloudFlare
* In the SSL/TLS → Edge Certificates tab, the setting “Always Use HTTPS” is set to On
Now all traffic is on https. Thank you so much for help @KangJL
Welcome
Make sure to mark the most helpful answer as the answer for others to solve stuff faster.
