Cloudflare not working
epiz_25346163
Domain luckygsm.com
Its enabled on cpanel for this domain
I create a free account on cloudflare, everything worked at the first time. And stopped working few hours laters. I didnt change anything on cloudflare settings that was automatically by cloudflare
Can anyone help me pls
Pls show CloudFlare dns entry…
Never ever do that,it breaks your websites and DNS entries
Yep, the integration is absolute trash. Never ever use cloudflare integration on cPanel best to use it directly from dash.cloudflare.com
  • Delete the cloudflare cname records
  • Delete the site from cloudflare
Then Go
  • Go to https://cloudflare.com
  • Follow the setup instructions (including nameservers)
  • Add these CNAME records (through cloudflare)
  • Make sure these are unproxied (by clicking the orange cloud, a little menu apprears. Click the orange clouds on that menu
  • Name: @ value: yourmaindomain.epizy.com
  • Name: www Value: @
I hope this helps :slight_smile:
