I try to use a cloudflare dns on my site but when I try to access the site by the ip with the dns: “m.deni.site-pro.ml” I am redirected to the page "http: // suspended-website.com/ "whereas if I access the site by: " site-pro.ml "everything works correctly.
I don’t think you can create one letter sub-domains, were you able to do that in the control panel?
this is not a subdomain, it is a “record a” created with cloudflare dns
There is a subdomain of “m” in this URL. You cant use that unless you create the subdomain in the control panel
it means that if I create the “deni” subdomain there will be no more problem
likely no issue
