Changing domains
Current Domain: apstudy.org
Goal Domain: old.apstudy.org
My plan is to change my domain from apstudy.org to old.apstudy.org and free up apstudy.org for another use. I am using Cloudflare and WordPress.
How can I do that?
you can download the files that are in the apstudy.org folder and upload them to the old.apstudy.org folder as infinityfree creates folders for domains
then delet ethe stuff in apstudy.org folder
You’ll need to do at least the following:
  1. In the settings of your WordPress site, change the site URLs and replace apstudy.org to old.apstudy.org.
  2. Move your files from the directory that apstudy.org is linked to to the the old.apstudy.org/htdocs directory.
You can either download the files and reupload them, but that’s a pretty slow process. Moving the files is faster.
Awesome, thank you both so much!
i dont know hows to move files in filemanager.ai i have filezilla but i use filemanager.ai instead of vscode and filezilla i oly use vscode for local project
