Changes are not reflected on my page
Having problems uploading data, I migrated it to FileZilla, after that the changes have not been reflected and when trying to use the page it does not go beyond the initial page which is a login, the error that appears is an HTTP error 500.
Upon doing a little research, the error is…
Fatal error : Uncaught mysqli_sql_exception: No such file or directory in /home/vol5_7/infinityfree.com/if0_35906114/htdocs/php/conexion_be.php:3 Stack trace: #0/home/vol5_7/infinityfree.com/if0_35906114/htdocs/php/conexion_be.php(3): mysqli_connect(‘localhost’, ‘root’, Object(SensitiveParameterValue), ‘login_register_…’) #1/home/vol5_7/infinityfree.com/if0_35906114/htdocs/php/login_usuario_be.php(5): include(‘/home/vol5_7/in…’) #2 {main} thrown in /home/vol5_7/infinityfree.com/if0_35906114/htdocs/php/conexion_be.php on line 3
Fatal error : Uncaught mysqli_sql_exception: No such file or directory in /home/vol5_7/infinityfree.com/if0_35906114/htdocs/php/conexion_be.php:3 Stack trace: #0 /home/vol5_7/infinityfree.com/if0_35906114/htdocs/php/conexion_be.php(3): mysqli_connect(‘localhost’, ‘root’, Object(SensitiveParameterValue), ‘login_register_…’) #1 /home/vol5_7/infinityfree.com/if0_35906114/htdocs/php/login_usuario_be.php(5): include(‘/home/vol5_7/in…’) #2 {main} thrown in /home/vol5_7/infinityfree.com/if0_35906114/htdocs/php/conexion_be.php on line 3
You need to enter valid information.
