Cgi-bin directory automatically created
Username epiz_28490416 and Website URL http://tfarotgaming.ga
cgi-bin/
Today when I was developing same website in my developing environment, redirects me to the actual live site and I saw somewhat like ‘Page not found’ and then I went on my FTP server and everything was perfect as usual but still it shows same message then I went on main page i.e. tfarotgaming.ga/ anddd it shows "
Index of /
[Name]|[Last modified]|[Size]|[Description]
cgi-bin/ 2022-04-17 03:53|"
Then I thought it would be my fault somewhere so I decided to delete all the files and reupload them but after deleting all files that same message was showing
I am exhausted in searching solution for that issue!
Please help me out…
and my all sub domains are working as usual…
Hello.
I am confused as to what the problem is. When uploading files, you need to upload them to the /htdocs folder.
AFAIK the cgi-bin directory is created on some hosting platforms to be able to run scripts in the Perl programming language.
However, our hosting doesn’t support this, and as such doesn’t create any cgi-bin directory.
So combined with the other Page Not Found issues, I’m suspecting that you may have been connected to another server than those provided by us. What you were connected to then, I don’t know, as far as I can tell your domain is correctly set up for our hosting.
