Can't Type Text Body while Creating Posts or Pages in WordPress
Hello! I just installed WordPress & when I try to create a page or post, I can’t type that…
I have installed the Classic Editor Plug-in. But even when I use the Block Editor, I can type the text but that doesn’t publish saying: Publishing failed. You are probably offline. Please help me out!
I don't know if there's another category for this, but I found the Hosting Support category to be more related!
So, Should I disable Force HTTP to HTTPS in Cloudflare?
Yes.
Thanks to you all MODS! It solved my problem! But now how I redirect my site to HTTPS without this issue? I have a free domain which doesn’t provide SSL.
Thanks again!
You should use Really Simple SSL plugin.
No, that option is probably fine. The Automatic HTTPS Rewrites option tends to be the root of a lot of evil.
And like @anon19508339 said: the Really Simple SSL plugin does what it says on the tin.
OK! Thank you for solving my issues :grin:
