Can't connect to site without js
miner.free.nf
This site requires Javascript to work, please enable Javascript in your browser or use a browser with Javascript support
I wanted to use the site servers to work the application is written in the block programming language catrobat (pocketcode). The only way to access the network is to send a web request and save the received html code in a local variable. But after I tried to use this site I got this error. If you do not understand, then sending a web request is just saving the html code in a variable and that’s it. I can’t manage it in any way
Welcome to the forum
Infinity free is designed for website hosting, not app or API hosting, as such there is a security system that makes sure only browsers can access your site
hope that helps :slight_smile:
