Cant connect to Control panel
trying since yesterday to log on my control panel, but all i get is the message:
“We are unable to log you in with the information you provided. Please check your username and password and try again 1”
I Know that t my login and password are right.
Then, iv’e tried to reset the password anyway, but no email is delyvered/received.
jus dont know what else i can do… any ideas?
Where did you do this?
Hopefully is from the client area.
Otherwise it will not work…
direct on cpanel (lost password)
the problem is: I cant config my email if I cant login the DNS config…and I cant login whitout config my emal…
so, I DO HAVE the login and password that ARE NOT WRONG, but the control panel does not conect.
Tryed again, and this time worked.
