Hello,
I can’t add the 2 mandatory TXT fields required for Mailgun to work.
How to do that?
Thanks
Hello,
How to do that?
Thanks
Please use the search feature next time, many questions have been answered already! For example, the same question has been asked yesterday as well: https://infinityfree.net/forum/topic/647/gghow-to-verify-txt-record-to-the-dns-configuration/post-2235#post-2235
Pleae beleave me I read half an hour though the forum how to make the email work and it still doesn’t work.
You suggested in some thread to use Mailgun as an email service but to properly use it you have to add TXT records, and you specified in other thread that you can’t add TXT records.
So my question is how to add Mailgun, because it won’t work without those TXT records?
Thanks
In that case I’m not sure you can actually use Mailgun. We’ll have to update that documentation.
However, it looks like Sendgrid only requires you to create CNAME records to verify your domain, which means it should work fine with the tools available.
