bigshado.com sent an invalid response.
ERR_SSL_PROTOCOL_ERROR
i used free ssl certificate and loged to my site and changed from http to https but now i cannot access wp-admin
Please do not do multiple posting
it still doesn’t work even after changing .htaccess file
it still show the same errors
Before you start changing the .htaccess file, you NEED a SSL certificate first. Follow these guide first:
If you want an SSL certificate that’s trusted by browsers, it must be provided by a known SSL certificate provider, also called Certificate Authority. InfinityFree integrates with multiple SSL providers, because different SSL providers are better suited for some circumstances. This article details the various options we support, and which we recommend for you.
Which SSL providers are available?
Let’s Encrypt
Let’s Encrypt is the world’s largest SSL certificate provider. Let’s Encrypt changed th…
In order to get a padlock in the address bar in your website, you need to install an SSL certificate on your website. This article describes how to do that.
If you would rather watch a video, scroll down to the bottom of this article.
Installing an SSL certificate
The first step to install an SSL certificate is of course to get the SSL certificate. You will need to get your SSL certificate from a certificate vendor of your choice. InfinityFree also provides free SSL certificates in the client …
thanks alot after changing my phpmyadmin it worked but still have a problem,still my site is showing that it is not secure .
note that what i have done is changing my siteurl from https to http only
Have you installed the ssl certificate first?
KangJL
July 9, 2023, 8:29am
11
You have SSL cert but you did not install it.
Please do so
yes i installed it on infinity free
I don’t think so yet; I think you still didn’t click the link to the article, and if you didn’t click it, I’ll force you to do so: click here !
Oh no, I intervened at the wrong time. Now it’s working for @KangJL ; you can now change your website URL to HTTPS on the database again.
KangJL
July 9, 2023, 8:38am
15
Seems doing this will not work well on free hosting
That only if he was using Cloudflare’s Flexible SSL; he isn’t using that (the nameservers are still pointing to our nameservers).
oooh on my pc my wp-admin panel is secure and other page but main page(homepage) is still showing it is not secure, may be it is problem with ma pc
KangJL
July 9, 2023, 8:55am
18
Clear browser cache?
Make sure to do this
After you’ve enabled SSL for your website, you’ll probably want to redirect all traffic on your website to the https version of your site. There are multiple ways to do that. Let’s compare some commonly used ways.
Using script configuration
Some scripts (including Wordpress) have a setting which allows you to set your website URL. By changing this URL from http://example.com to https://example.com , the script will probably redirect visitors to the https version of your site. Even if your script…
