Hi all.
when i install snipeit in hosting have a error. Can i help me fix it
"The following errors were found :
Could not make the query numbered : 8
MySQL Error No : 1071
MySQL Error : Specified key was too long; max key length is 1000 bytes"
Hi all.
That software requires InnoDB, which is not supported on free hosting. So you can’t install that software, and you should find alternatives to it or upgrade to Premium Hosting to install that software.
