Can anyone help me with .htaccess?
http://cmluebrfu.rf.gd/
500 Internal Server Error
Oops, something broke when loading the page you requested! This is usually caused by bad .htaccess code or an error in your PHP code. Learn More.
Basically I want protect my website insert a password but don’t work? Anyone can help me to configuarate it? I insert in /htdocs folder the files .htaccess and .htpasswd
.HTACCESS FILE IS
AuthType Basic
AuthName "Password Protected Area"
AuthUserFile htpp://cmluebrfu.rf.gd/htdocs/.htpasswd
require valid-user
You can use the Directory Privacy feature in cPanel, it is easier to set up that way and you don’t have to worry about any misconfiguration. But, if you wish to do it this way, please follow this article as it describes the correct way to implement this:
This should probably be:
AuthUserFile .htpasswd
AuthUserFile requires a local file path, not the URL to a website.
Also, I would strongly recommend to use our Directory Privacy function for this instead.
