(https://icare.great-site.net/)
(Server returning error 500)
index.php
<?php
use Illuminate\Contracts\Http\Kernel;
use Illuminate\Http\Request;
define('LARAVEL_START', microtime(true));
while (ob_get_level()) ob_end_clean();
ini_set('zlib.output_compression', 0);
ini_set('implicit_flush', 1);
if (file_exists($maintenance = __DIR__.'/../storage/framework/maintenance.php')) {
require $maintenance;
require __DIR__.'/../vendor/autoload.php';
try {
$app = require_once __DIR__.'/../bootstrap/app.php';
echo "Bootstrap loaded successfully<br>";
$request = Request::capture();
echo "Request captured successfully<br>";
$response = $app->handleRequest($request);
echo "Request handled successfully<br>";
$response->send();
} catch (Throwable $e) {
$error = date('Y-m-d H:i:s')." - ".$e->getMessage()." in ".$e->getFile().":".$e->getLine().PHP_EOL;
echo($error);
The output is showing up until
which means the request isn’t being handled, I’ve checked all my .env & database but all is not helping
