Bootstrap navbar not expanding on live site but works fine locally
https://trilliumagency.ca
I am using bootstrap and jquery when i use navbar to expand it doesn’t work on the live site but it works when i try it locally.
can you provide the navigations code, it is look like there might be an error in your code
Hi and welcome to the forum, the reason for what you face is due to this:
You may fix the error by uploading those missing files.
Thanks I uploaded the bootstrap file and it worked sorry for the bother and thanks again
No worries! Issues like that can happen.
