I am getting a blank page when i load my website, I have uploaded all files and checked to be sure everything is okay, yet nothing is working, if i try to change the location of a file, it will display error message, it gets back to blank page once i correct it.
But then the error page also generates an error and redirects to the error page, which generates an error and redirects to the error page, etc. etc.
So I think there are two things you should do here:
Figure out why this “An error might have occurred in the system” is being generated in the first place, and fix that.
Ensure that if an error does occur, the system will display an error page correctly and not go into a redirect loop.
I took a quick look at your code to see if there was an easy to find answer, but your site looks quite complex and completely custom coded. I personally won’t be able to help you without digging into the code base and debugging it, which is not really something I want to do.
