Problem: The website opens successfully on Airtel mobile data and Jio Wi-Fi, but does not open on Jio mobile data.
Error message: This site can’t be reached.
The website is working correctly on my laptop and other network connections. Please investigate whether this is related to DNS resolution or network accessibility on Jio mobile data.
What exact error code does Chrome show under “This site can’t be reached” on Jio mobile data? It will be something like DNS_PROBE_FINISHED_NXDOMAIN or ERR_CONNECTION_TIMED_OUT. The code tells us whether Jio can’t look up the address or can’t connect to the server, and those are different problems.
Others have reported the same pattern with Jio mobile data and free subdomains. In that topic, the site only opened after they set Android’s Private DNS to dns.google:
I think yours might be the same thing. Does your site open on Jio mobile data if you set Private DNS to dns.google? If it does, that points to a DNS lookup problem on Jio’s side.
If the code is a connection error instead, our article on this error covers it. It says some internet providers block websites themselves. It also has a test using Globalping that shows whether other customers of the same provider can reach your site:
In that case, typing http://bitenova.rf.gd/ by hand on Jio mobile data would also help. If HTTP opens but HTTPS doesn’t, the article says the cause is almost certainly the network or provider.
I tested the website on different network connections:
Airtel mobile data – Working
Jio Wi-Fi – Working
Jio mobile data – Not working (shows “This site can’t be reached”)
Another user is also experiencing a similar issue.
Could you please investigate whether this is a Jio mobile network or DNS-related issue? Is there any solution that would allow all Jio mobile users to access my website without changing their individual DNS settings?
Are you sure that it’s a DNS issue? The “This site can’t be reached” error is a connection error, not a DNS lookup error.
We have an article with that exact error page here with some possible explanations and things you could check:
If it really is a DNS error, then this article would apply:
Besides that, there have been more reports recently of people unable to open their website from Reliance Jio connections, so it seems pretty likely that they are blocking access to our hosting from their end.
But since they are doing the blocking, we cannot solve that from our end. Please contact Reliance Jio to check the issue from their end.
