base href does not work for my site
Hello,
I use in all my html pages, then all css, images, … are pointed directly from the base directory.
However, it does not work for html files located in the “livres” directory for example.
Example: http://www.yoga-kids.net/livres/index.html contains and points to css files through href=“css/main.css”. But this css file does not seem to be loaded.
Where is my mistake here?
Thank you,
Chris.
I think the issue is with using relative URLs. If you use a relative URL without a slash in front (like css/main.css), the URL will be resolved relative to the directory of the current page. So your browser is likely trying to load http://www.yoga-kids.net/livres/css/main.css
How to fix that? Simple: put a slash in front of the URL (like /css/main.css). That way, the URL will be linked to the root of the domain name, regardless of which directory you are currently viewing.
Hello Admin,
Thank you for your answer.
I updated all the relative path with / in front. But it does not change anything.
When I have a look at the “page source” of “http://www.yoga-kids.net/livres” from my browser, it displays a source code with frameset which is not my code, but added by
Infinityfree (?):
<html>
<head>
<title>www.yoga-kids.net</title>
</head>
<frameset>
    <frame src="http://yoga-enfant.epizy.com/livres" name="redir">
    <noframes>
      <p>Original location:
        <a href="http://yoga-enfant.epizy.com/livres">http://yoga-enfant.epizy.com/livres</a>
      </p>
    </noframes>
</frameset>
</html>
I guess my problems comes from there.
Would it be possible to remove that frameset redicrection?
Thank you,
Chris.
@ChrisL said:
Hello Admin,
Infinityfree (?):
<html>
<head>
</head>
<frameset>
    <noframes>
      </p>
    </noframes>
</frameset>
</html>
Thank you,
Chris.
I checked your website again and I think I overlooked something before.
Your website page uploaded here has the following HTML attribute at the top of the file:
<base href = "http://www.yoga-kids.net/">
What this does is change the logic of the relative URLs. So /css/main.css doesn’t go to http://www.yoga-enfant.epizy.com/css/main.css, but to http://www.yoga-kids.net/css/main.css instead. And since http://www.yoga-kids.net/css/main.css is not a CSS file but a HTML (with the actual CSS text in a frame), the styles don’t work.
There are two ways to solve this:
  • All the asset links in the page must have a full URL including domain name.
  • The base href attribute must be removed.
Hello Admin,
Thank you for your feedbacks.
So, I understand that due to Infinityfree frameset, there is a difference for any resource file (html, css, images…) between http://www.yoga-kids.net/ and http://www.yoga-enfant.epizy.com/. Right?
Therefore, it means that I cannot include in my html files any resource with http://www.yoga-kids.net/. Right?
Then it leads to another issue for me.
I did use that base href + .htaccess in another web hoster to have subdomains. I understand it will not work with Infinityfree.
My objective is t have a few sub-domain for www.yoga-kids.net, such as livres.yoga-kids.net, cours.yoga-kids.net, and formation.yoga-kids.net. These subdomains points to different folders: www.yoga-kids.net to root folder, livres.yoga-kids.net to livres folder…
Some css, images, and other resources are common to html (or php) files for these sub-domains, and located under the root domain (e.g www.yoga-kids.net/).
I understand that I cannot use base href to point (and use relative path) to these resources, right? Then, does it mean that I cannot specify www.yoga-kids.net// (even with absolute path)? But only yoga-enfant.epizy.com// (with absolute path)? Not very handy!
Cheers,
Chris.
Sorry, the (inferior sign) and (inferior sign) were removed in my lat paragraph.
You should read:
I understand that I cannot use base href to point (and use relative path) to these resources, right? Then, does it mean that I cannot specify:
www.yoga-kids.net/<folder>/<resource>
(even with absolute path)? But only:
yoga-enfant.epizy.com/<folder>/<resource>
@ChrisL said:
Hello Admin,
Almost. The frameset is not configured by us, but by Gandi. And the frames are not the problem here, the base href tag is.
Exactly.
Cheers,
Chris.
The main issue is that URL Forwarding/Masking using HTML frames (which is what Gandi did for yoga-kids.net) is a major limitation. You can’t completely hide the original subdomain, because URL Masking simply cannot allow you to do that.
If I were you, I would do the following:
  • Add yoga-kids.net as an addon domain to your hosting account here. That does involve changing your domain’s nameservers, but that’s quite straight forward.
  • Use the Subdomains menu to create livres.yoga-kids.net, cours.yoga-kids.net, etc. These subdomains will get their own directories with their own website.
The disadvantage of that setup is that you cannot show the same content on livres.yoga-kids.net and yoga-kids.net/livres/ (without manually uploading the same files to both folders). But beyond that, your website is completely white label and doesn’t use the free subdomain anymore.
