Arc installation not working
epiz_29481613
Your service worker (my website and where the service worker is) has a non-JavaScript content type: text/html. To fix, change the content type to a JavaScript content type, like “application/javascript”.
The error keeps coming up when I try to install Arc. Is it something with Cloudflare?
Could you be a little more specific? You mention a server worker, what is that? If something has a MIME of text/html, and is supposed to be text/javascript you should make sure that the extension is .js (not .html), and any internal coding is set correctly (For example, no HTML DOCTYPE or other tags in the file).
Others have installed Arc successfully, so it does work here.
The service worker is what powers Arc and its CDN. The service worker’s extension is .js and there are no other tags in the file.
Was this a typo then? You might just want to try again.
Alright.
