epiz_25971206
Arabic language show as ???
And also the french language didn’t view probably with some ???
I don’t what is the problem… It’s not in the code and it works fine in my localhost so, what is the problem?
Thank You…
Hello there,
If your site is just a basic HTML webpage then you try inserting this head tag (<head>)
in your html file:
<meta charset="utf-8">
It contains it in all the pages
Sorry but what did you mean exactly?
That the is in all the pages
That The meta tag is in all pages
katufo
June 10, 2020, 10:49am
7
Please be specific. Your website works fine for me, All English language.
Hi there. Did you implement the html language tags?
If not, then write this on the second line before other html codes:
1. For Arabic:
<html lang=“ar”>
2. For French:
<html lang=“fr”>
May this code helps you. Happy Coding!
In Arabic and English after logging in as a visitor
katufo
June 10, 2020, 11:06am
10
In your HTML file, change this tag < html lang=“Eng” > to < html lang=‘en-US’ >
Find this tag < meta charset=“utf-8” >, change it to < meta http-equiv=“Content-Type” content=“text/html;charset=UTF-8” >
Remove those spaces after the < and before >.
system
Closed
June 25, 2020, 11:06am
11
