It depends on where the API code would actually run, so which is it? Is the Cloudflare domain pointed at your InfinityFree account, or would the API be hosted somewhere else, such as another provider or a Cloudflare service?
If the Cloudflare domain just points at your InfinityFree hosting, it won’t help. The browser security check is part of the hosting, not the domain, so it covers every URL on the account and can’t be turned off for one path. The article says this directly:
The article describes what’s blocked: REST API requests from tools and scripts, and AJAX requests from other domains (CORS). It also says what keeps working: JavaScript calls to endpoints on the same domain, and your site’s own server-side code making requests to external services. The check only applies to requests coming in to an InfinityFree site, so an API hosted elsewhere wouldn’t be subject to it. The articles don’t describe that exact setup, though, so I can’t promise how it would behave.
The second article lists your options for API access: premium hosting, a different service for the API, or having your site make outbound requests.
