An SQL error occurred: SQLSTATE[42000]:
https://gradingsystem.great-site.net/
Sample Account
username: Sample123
password: Sample@123
DataTables warning: table id=uploadGradeTable - An SQL error occurred: SQLSTATE[42000]: Syntax error or access violation: 1104 The SELECT would examine more than MAX_JOIN_SIZE rows; check your WHERE and use SET SQL_BIG_SELECTS=1 or SET MAX_JOIN_SIZE=# if the SELECT is okay
In my machine its working and this is the expected Return
{“draw”:1,“recordsTotal”:7,“recordsFiltered”:7,“data”:[[3,“Chicky Bracchi”,“[{"component_value_id": 97, "student_grade": 95, "student_id": 8, "component_value": 100},{"component_value_id": 98, "student_grade": 10, "student_id": 8, "component_value": 10},{"component_value_id": 99, "student_grade": 0, "student_id": 8, "component_value": 0},{"component_value_id": 100, "student_grade": 0, "student_id": 8, "component_value": 0},{"component_value_id": 101, "student_grade": 0, "student_id": 8, "component_value": 0},{"component_value_id": 102, "student_grade": 70, "student_id": 8, "component_value": 100},{"component_value_id": 103, "student_grade": 95, "student_id": 8, "component_value": 100},{"component_value_id": 104, "student_grade": 0, "student_id": 8, "component_value": 0},{"component_value_id": 105, "student_grade": 0, "student_id": 8, "component_value": 0},{"component_value_id": 106, "student_grade": 0, "student_id": 8, "component_value": 0},{"component_value_id": 107, "student_grade": 8, "student_id": 8, "component_value": 10},{"component_value_id": 108, "student_grade": 45, "student_id": 8, "component_value": 75}]”,“1230”,“M”],[3,“Fourth S. Student4”,“[{"component_value_id": 97, "student_grade": 98, "student_id": 7, "component_value": 100},{"component_value_id": 98, "student_grade": 9, "student_id": 7, "component_value": 10},{"component_value_id": 99, "student_grade": 0, "student_id": 7, "component_value": 0},{"component_value_id": 100, "student_grade": 0, "student_id": 7, "component_value": 0},{"component_value_id": 101, "student_grade": 0, "student_id": 7, "component_value": 0},{"component_value_id": 102, "student_grade": 70, "student_id": 7, "component_value": 100},{"component_value_id": 103, "student_grade": 70, "student_id": 7, "component_value": 100},{"component_value_id": 104, "student_grade": 0, "student_id": 7, "component_value": 0},{"component_value_id": 105, "student_grade": 0, "student_id": 7, "component_value": 0},{"component_value_id": 106, "student_grade": 0, "student_id": 7, "component_value": 0},{"component_value_id": 107, "student_grade": 9, "student_id": 7, "component_value": 10},{"component_value_id": 108, "student_grade": 69, "student_id": 7, "component_value": 75}]”,“1230”,“M”],[3,“New R. Student”,“[{"component_value_id": 97, "student_grade": 92, "student_id": 9, "component_value": 100},{"component_value_id": 98, "student_grade": 10, "student_id": 9, "component_value": 10},{"component_value_id": 99, "student_grade": 0, "student_id": 9, "component_value": 0},{"component_value_id": 100, "student_grade": 0, "student_id": 9, "component_value": 0},{"component_value_id": 101, "student_grade": 0, "student_id": 9, "component_value": 0},{"component_value_id": 102, "student_grade": 70, "student_id": 9, "component_value": 100},{"component_value_id": 103, "student_grade": 70, "student_id": 9, "component_value": 100},{"component_value_id": 104, "student_grade": 0, "student_id": 9, "component_value": 0},{"component_value_id": 105, "student_grade": 0, "student_id": 9, "component_value": 0},{"component_value_id": 106, "student_grade": 0, "student_id": 9, "component_value": 0},{"component_value_id": 107, "student_grade": 10, "student_id": 9, "component_value": 10},{"component_value_id": 108, "student_grade": 44, "student_id": 9, "component_value": 75}]”,“1230”,“M”],[3,“Eduardo Tacorda”,“[{"component_value_id": 97, "student_grade": 1, "student_id": 6, "component_value": 100},{"component_value_id": 98, "student_grade": 5, "student_id": 6, "component_value": 10},{"component_value_id": 99, "student_grade": 0, "student_id": 6, "component_value": 0},{"component_value_id": 100, "student_grade": 0, "student_id": 6, "component_value": 0},{"component_value_id": 101, "student_grade": 0, "student_id": 6, "component_value": 0},{"component_value_id": 102, "student_grade": 70, "student_id": 6, "component_value": 100},{"component_value_id": 103, "student_grade": 70, "student_id": 6, "component_value": 100},{"component_value_id": 104, "student_grade": 0, "student_id": 6, "component_value": 0},{"component_value_id": 105, "student_grade": 0, "student_id": 6, "component_value": 0},{"component_value_id": 106, "student_grade": 0, "student_id": 6, "component_value": 0},{"component_value_id": 107, "student_grade": 5, "student_id": 6, "component_value": 10},{"component_value_id": 108, "student_grade": 0, "student_id": 6, "component_value": 75}]”,“1230”,“F”],[3,“Student F. Gender”,“[{"component_value_id": 97, "student_grade": 85, "student_id": 11, "component_value": 100},{"component_value_id": 98, "student_grade": 9, "student_id": 11, "component_value": 10},{"component_value_id": 99, "student_grade": 0, "student_id": 11, "component_value": 0},{"component_value_id": 100, "student_grade": 0, "student_id": 11, "component_value": 0},{"component_value_id": 101, "student_grade": 0, "student_id": 11, "component_value": 0},{"component_value_id": 102, "student_grade": 95, "student_id": 11, "component_value": 100},{"component_value_id": 103, "student_grade": 70, "student_id": 11, "component_value": 100},{"component_value_id": 104, "student_grade": 0, "student_id": 11, "component_value": 0},{"component_value_id": 105, "student_grade": 0, "student_id": 11, "component_value": 0},{"component_value_id": 106, "student_grade": 0, "student_id": 11, "component_value": 0},{"component_value_id": 107, "student_grade": 9, "student_id": 11, "component_value": 10},{"component_value_id": 108, "student_grade": 36, "student_id": 11, "component_value": 75}]”,“1230”,“F”],[3,“Student S. Gender”,“[{"component_value_id": 97, "student_grade": 94, "student_id": 10, "component_value": 100},{"component_value_id": 98, "student_grade": 10, "student_id": 10, "component_value": 10},{"component_value_id": 99, "student_grade": 0, "student_id": 10, "component_value": 0},{"component_value_id": 100, "student_grade": 0, "student_id": 10, "component_value": 0},{"component_value_id": 101, "student_grade": 0, "student_id": 10, "component_value": 0},{"component_value_id": 102, "student_grade": 70, "student_id": 10, "component_value": 100},{"component_value_id": 103, "student_grade": 70, "student_id": 10, "component_value": 100},{"component_value_id": 104, "student_grade": 0, "student_id": 10, "component_value": 0},{"component_value_id": 105, "student_grade": 0, "student_id": 10, "component_value": 0},{"component_value_id": 106, "student_grade": 0, "student_id": 10, "component_value": 0},{"component_value_id": 107, "student_grade": 10, "student_id": 10, "component_value": 10},{"component_value_id": 108, "student_grade": 57, "student_id": 10, "component_value": 75}]”,“1230”,“F”],[3,“Student S. Inside”,“[{"component_value_id": 97, "student_grade": 0, "student_id": 12, "component_value": 100},{"component_value_id": 98, "student_grade": 9, "student_id": 12, "component_value": 10},{"component_value_id": 99, "student_grade": 0, "student_id": 12, "component_value": 0},{"component_value_id": 100, "student_grade": 0, "student_id": 12, "component_value": 0},{"component_value_id": 101, "student_grade": 0, "student_id": 12, "component_value": 0},{"component_value_id": 102, "student_grade": 70, "student_id": 12, "component_value": 100},{"component_value_id": 103, "student_grade": 70, "student_id": 12, "component_value": 100},{"component_value_id": 104, "student_grade": 0, "student_id": 12, "component_value": 0},{"component_value_id": 105, "student_grade": 0, "student_id": 12, "component_value": 0},{"component_value_id": 106, "student_grade": 0, "student_id": 12, "component_value": 0},{"component_value_id": 107, "student_grade": 5, "student_id": 12, "component_value": 10},{"component_value_id": 108, "student_grade": 62, "student_id": 12, "component_value": 75}]”,“1230”,“F”]]}
The error is under of the List of course/subject
The error suggest that our server don’t accept such big queries, while your local machine might do.
The solution is right in the error message, though there’s no guarantee whether it would work on our servers or not:
SET SQL_BIG_SELECTS=1;
or
SET MAX_JOIN_SIZE=<Some big number>;
You have to execute these before the real SELECT query. If these didn’t work, however, you might want to optimize your code. (I suppose this is custom coded.)
