Am not getting any help as I said this was all working remotely from my PC until the 28th November 2022 having worked 27th November 2022 posting data which is evident on your side and in database as being populated Your OX user verified he could place data on a web page verifying the functionality of my code. I referred this to my legal they wrote to ionis today to ask why providing contact and personal information with another network supplier you must know. I am sending you data on my application approx. every 3-7mins on this page http://www.deniserose.epizy.com/add_track_blob2.php I can see no activity or evidence of this connection on my website so were is this connection going if not to this web address address you must now if my web site has this activity and if these connections to my server are being made? You have blamed my coding which has worked before with tweaks to fit your environment. I would of thought this would have been straightforward to show this evidence of these high number of data connections as nothing is indicating any failure. Other that my database is not receiving data when up to the 27th November it did . I refer you to my logins during this week ending the 4th December which was absent as some of the site was working ad I was happy knowing there was other parts to improve over time .So what is causing this latency our outage when there is no error on my side or anything to indicate a failure which neither Microsoft or my ISP could identify. In fact when they reset the router the system reported this network failure indicating it was working correctly.
As you have not responded I have been asked to place a fault response on line 2 and 3 of my code to add to sql and shorten the name of the PHP file inn case the url was too long
throw Error("EXIT CODE");
exit();
I will run this 12 hours to see if you detect these faults or if they are reported back to my computer or my network traffic is being error or are being intercepted so that it does not get to you.
I have now changed this to throw Error(“500”); instead of throw Error(“EXIT CODE”);
which in browser gives error Fatal error : Uncaught Error: Call to undefined function Error() in /home/vol1_2/epizy.com/epiz_33087480/htdocs/REDACT.php:3 Stack trace: #0 {main} thrown in /home/vol1_2/epizy.com/epiz_33087480/htdocs/REDACT.php on line 3
I should expect this error to be returned to me then every time my code is accessed as it does in the browser which doesn’t this makes me believe either you are not getting this response rom my device or my network communications are being intercepted as Lee informed us was something he could see on his CISCO router being put in place by this other company . I urge you to respond and inform me if your see this response error generated which is being sent out from you for approx. 2520 in 12 hours times? Or if it is not evident .
And… how are you sending this data exactly?
I’m sorry, we don’t. We don’t store web server access logs so I can’t tell you if the requests actually came through. And if they didn’t, show up there, then it still wouldn’t tell a lot about where in the process it doesn’t work.
Based on what you wrote before that, I understand that you have some kind of automated submission system that’s supposed to update the page every time a new track starts playing on whatever radio streaming that track list represents?
Does the tool that’s supposed to submit the data also log whether the track updates were sent at all? And does it log if the submissions were successful and what was returned? If we know that the submissions are still being sent, and we know of any errors encountered by it, that would help a lot in troubleshooting this.
What evidence? All I see is a vague description of “it was working before and it isn’t now, I didn’t change anything so you need to fix it”.
If you want to prove to me that there is something wrong with the hosting, then please provide me with reproduction steps I can follow that show that an issue exists with our hosting.
Because Error isn’t a valid exception class, unless you define it. But doing throw \ErrorException("EXIT CODE"); should work.
We have contacted Radio App supplier to test app Dmtri will look at tis to see if anything has changed and whether they can verify if it will sent to other sites This will prove system is working . I have in formed you that we was sending data as a port 80 html link to the website with parameters representing the fields from the radio program. in the same way a browser receives it but from a different origin known to Microsoft Defender .This then uses the same protocols and has worked without a problem recently I informed you we had run a tracert which you said you did not support however we are are at a loss how you expect communications to be resolved if your system is not traceable . However the limited trace did show error in latency when we asked the network man he said another company had a filter on it .
I’m beginning to think you may be running into this security system:
It blocks most kinds of API access, which could also block your radio app.
Although then I’m more surprised it worked before and not anymore now, because this security system should block API access anyways.
Web traffic and traceroute traffic is not the same. It’s trivial to block one but not the other. Traceroutes and pings not working is only an issue if they are supposed to be working. And with our network: those not working is by design.
We indeed have a filter on “it”, with “it” being the traceroutes and pings to our servers. I told you as much. Anyone with a moderate understanding of networking can verify that what I’m saying is possible, which is what your network guy did.
The one hop with high latency is again not an issue. The latency of a router is often higher than the actual overhead on a connection go through it. If I ping my home router I also get much worse results than if I ping another computer attached to that router. Why? Because routers are optimized to route traffic, not respond to traffic. Routers use purpose built chips to route traffic quickly, but pings are handled by software.
The fact that in the same traceroute the hop after the slow hop shows much lower latency proves this. If the router was actually slowing down the traffic, then everything after it would be slower, not faster.
Have a good day everyone.
I’m edit my code to getting closer to your code.
I believe your code just need a little change to work nice.
But, I manage on my way. So i edit some plugin and plan to attach other plugin css. Here is the progress:
http://viena.lovestoblog.com/plugins/imgUpdate/
please dont delete. Be nice it will be good in view days.
Well you have made no progress in tracing my traffic error to my app. As I explained yesterday to you my ISP reset my router whilst it was broadcasting which allowed the network traffic to be cut locally my App , which detected the loss of network on all traffic. Therefore the fault is not local to me or our devices The app supplier is of the normal opinion if all this worked before where is the change ?
Edwin a hard error stop was introduced into the add file to create an error reaching down the web to our device. This should report back 500 error anyone using the URL to add a track .
Admin the same Microsoft Defender has been run throughout its firewall defected the app and added a route through it when the app was installed. After disabling FTP of image upload which functioned .I sent 12 hours of use of my site up to your site yesterday and it is not apparent anything like an error came back .
I asked you to check activity on my site to see if this error was evident which you have not provided latency rose on the tracert on a cloud server to your location from 94s to over 250ms which is a lot when you consider it should be 8ms and is indicative of a cisco router fault.
As I explained this just gives TimeOut error from my device which you stated was because you cannot ping an infinity website. I really do not see how you can fault find your network perhaps you could advise how these faults and errors is monitored?
You state your network is acting under how it was designed. Are you suggesting you have turned off this communication from my device and for what purpose that was done ? I asked you to note you said you had not blocked it . Why was then there after you stating it was my code when yo new full well it was your newly placed filter I presume you are the other company indicated on my legal email to infinity?
Furthermore if its working as it should by designed! what happened 28th November 2022 when you seem to be stating in round about way you placed a filter to block my device traffic from anything other than a browser. Have you not then been wasting my time being compromised with the truth in this matter rather than direct and easily to understand? Your indicated reason for this failure Ensuring only web browsers can access your website allegedly came in 1st of August 2022 so then why did this not effect any service until 28th Novembers 2022 . I fact you are well i was coding through this on my site and on your forum . You seem to have deprived me of this information from the start wasting my recourses . Is this now an webhost company such as IONIS should operate to wards its customers? f as you have the reason above . Can you inform me how FTP packages get through this as clearly they are not browsers either . It does not seem reasonable or genuine what you are suggesting then and more likely you have placed a filter to block this access with this filter whilst informing me how to ensure my code worked properly.
@Admin can you please inform me what your ‘filter’ Ensuring only web browsers can access your website looks for to determine if its a browser as this might be missing from my software that’s browser sends out to you ?
As clearly described in the article, it tries to set a cookie through JavaScript which would require that your “browser” supports JavaScript and can store cookies. Then it tests to see whether the cookie was actually set (through JavaScript) and tries to redo the process (setting the cookie through JavaScript) if it cannot detect that the cookie was set.
Thanks Wacky you are great Hugs ![]()
according to, Server error (500 error) - #10 by KangJL
Try to access page with http.
Admin: The easiest way is to just not specify the full URL and just let the browser auto-complete it.
Edwin and Admin,
I just spoke to Application supplier they said infinityfree.nnet is the only site implementing this alone Why would you do this then that places part off your customers unable to use SQL services ?
I’m watching this forums. And still talk about your topic.
I’m curious this http://inamsweb.ml/storage/emulated/0/MR/quiz.html css.
What the hell in the world. When we pointing on the object it halfing rolling down.
When you say all page return 500. I though this css make all page return 1000.
Just comment plz. If it doesn’t have relations to topics.
Yes, I know it’s an unusual system. Even on our platform, it’s only active on free hosting, premium hosting doesn’t have it. But it’s a necessity for the sustainability of our free hosting, so we’re not going to remove it. If this breaks you site, then I’m sorry, but your use case won’t work on our hosting.
You can use our SQL services without any problem! The only thing you can’t do is use external tools to automatically submit data to it.
Hypothetically, you could even make it work by reversing the data stream. So instead of your radio app pushing data to your website, your website could fetch the data from the radio app. Perhaps with an intermediary service that stores the track data, like an RSS feed. But that’s not exactly straight forward.
Yes but this is not true your site will not connect to SQL with anything other than a browser that can understand Javascript write a silly redundant not allowed because of tracking by most people file that can be read.
This was not implemented when it was working when I signed up with IONIS not infinityfree.net I have been told my legal asked IONIS to move my site to them as yours does not function here and you have placed block in my communications without any reason to do this while you was pretending to help me in the background. my data is being illegally diverted . I have repeated sked you were but you have not been forthcoming with a proper answer . oh I will ask you plainly as my legal put it .
@Admin ADMIN Who instructed your infinityfree.com to place this block on my communications 28th November 2022
Denise
For the last time, we did not place a communication block on your account.
And if you want to believe that we did, fine. Note that making such a block (If we did decide to take the time to figure out how to do that) could easily be circumvented by you creating a new account, and would be completely allowed within our terms.
Yes you did at ifinityfree.net otherwise it would still be reaching your site as it was fully working as a testament to the data in the database 27th November 2022 and before which I am aware as working for Infinityfree.net you can see in my [epiz_33087480__song_history]>>played_songs . How else did the data get there ? Sighs
infact the last entry is 2022-12-05 15:28:57 Surround Me with Your Love Blank & Jones with Coralie Clément Milchbar - Seaside Season 6 03:15 104 Dance & DJ 0 0 0 Amazon.com Song ID: which is just before after placed this block in my data reaching your site as there was no further data entered. Regardless of the actual date which is pedantic you placed this lock in place now stop being untruthful.
Now kindly provide this whole thread to my email account so that I can provide it to my legal for determination on whether they will sue for breach of contract and misuse of our personal data which you are in breach of Information Act in processing my data and not informing me how your are processing it . You are aware as a citizen I have a right under international GDPR law to verify this data you hold is correct . I have repeatedly ask you where you are sending it as it is not reporting any error and is not placing data in my SQL services.
Please provide your SERVICE address on same email containing this entire thread as printed pdf
