All web pages return http 500 not sure why
Take s look of this plugin. So i searching plugin for image playing matches. For highlighs cover.
Here i got it one
it was my DSP I reset computer as Microsoft said it was there 2005 update but nope still have no contact with your server it returns 403 if you try ping it or ping my website . The stupid reset reset everything and cured nothing … my transmit gets to here still is one of your servers down at IONIS
6 29 ms 37 ms 28 ms ae1.5.edge3.Manchesteruk2.level3.net [4.69.161.54]
7 26 ms 30 ms 25 ms WILDCARD-UK.edge3.Manchesteruk2.Level3.net [195.50.121.134]
8 24 ms 25 ms 20 ms vl504.cr-1.rel.ncl.wildcard.net.uk [31.22.6.27]
9 19 ms 23 ms 23 ms cust.te3-1.cr-4.rel.ncl.wildcard.net.uk [31.22.6.126]
10 * * * Request timed out.
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
14
You cant send to it is has a lock key sorry to my machine
Cant get into files section so something must be afoot hugs Dx
Also if i use my sites IP http://185.27.134.150/ it gets 403 Forbidden error any ideas why ?
If I understood your message correctly, you mean that I am unable to change the list because of a lock key?
the video is blurry for a reason…
yes it has a lock on it see http://www.deniserose.epizy.com/add_track_blob2.php
Of course, but I manage what will be displayed in the list - watch the video
(it means that I also have access to your DB)
when another song starts, it’s an update from your side - so overwrite happens
but someone can do it non-stop
Was it my imagination or did it just change the image . Now all i need is it to write the sql bust still cant reach the website from my app i am trying with ip instead lest see if it works
Try now please
Firefox
Edge
ow is it getting past this then
$key = isset($_REQUEST['key']) && ($_REQUEST['key'] !=='') ? $_REQUEST['key'] : false;
if($key==false|| $key != 'BlahBlah Bah' )  {
    ReturnError(500, '<b>Access Denied!</b> Failed to be provided security access. <br>Sorry we could not add your data as you do not have access please <br>contact site admin if you feel this should work.');
that’s normal…
because it’s not just the IP from your website, but a thousand others share the same IP.
look at that IP as the first door that then leads further
forget that file - has no role here
because another file to which I send data via URL manipulation - later it generates what will be in the DB
Rest a little… empty your head
tomorrow you will be smarter
yus but ReturnError has exit in it it should stop there ?
try again please
tried this too still no luck
-Look for WLAN Autoconfig and WWAN Autoconfig> Right-Click Properties and set it to automatic (If it’s already set to automatic, right-click then click stop then start it again)
-Restart the PC and check
If the issue persists, run the following command in Command Prompt (Admin). Follow the steps below to do so.
These sets of commands will reset the internet connection and re-calibrate the internet settings you have.
Press Windows Key + X.
Click on Command prompt (Admin).
Type the following commands, and hit Enter after each command:
netsh int tcp set heuristics disabled
netsh int tcp set global autotuninglevel=disabled
netsh int tcp set global rss=enabled
netsh winsock reset
netsh int ip reset
ipconfig /release
ipconfig /renew
ipconfig /flushdns
I sent the request again and succeeded
because it has nothing to do with what you’re trying to do right now or with that file you mention.
@Oxy
Your server at 31.22.6.27 is running to slow for me to connect its taking 95.488 s to respond. Can you help this was ok last week and is indictive of network failure or fault.
Hugs D
Hop Host IP Time (ms)
8 WILDCARD-UK.edge3.Manchesteruk2.Level3.net 195.50.121.134 6.024ms
9 vl504.cr-1.rel.ncl.wildcard.net.uk 31.22.6.27 95.488ms
10 cust.te3-1.cr-4.rel.ncl.wildcard.net.uk 31.22.6.126 8.440ms
@Oxy
Trying this tcpip - Which is the default TCP connect timeout in Windows? - Server Fault
Still not having any luck your server fault being to slow @ 31.22.6.27 is still taking more than 95s to respond there seems nothing much my end I can do to resolve this as its on your side not mine an you let me know when its fixed ? I have my TcpTimedWaitDelay set at 240s decimal but 95s is to much time wait when it should be 8s
