ALL "rf.gd" Subdomains Are Not Reachable Or Down Right Now
ALL “rf.gd” Subdomains Are Not Reachable Or Down Right Now !!
The domain and subdomains on it are working for me. Your connection is likely being blocked by a local firewall or your ISP if you can’t connect to the domain.
Try using a different device/ISP if you are able.
No, Check The Website Speed They Are Very Slow
I Have 3 Websites With rf.gd Subdomain All Of Them Are Unreachable Or Very Slow From Yesterdays Evening And Even Currently Its Not Working Fine The Elementors Also Not Loading Cleared Cache, Changed Browser, Different ISP Network, Different Devices Tried Everything Also When Entered In The DownDetector Website It Says That They Have High ICMP Ping Also Unreachable Some Times,
Please Help Me ASAP, I Am Completing A VERY Important Project Right Now !!
I’ve checked the base domain (rf.gd) and its working fine. And my own rf.gd domain is running fine too. If you’d like to share your domains, I can take a look at them for you.
So this suggests one of 2 problems:
  • your sites specifically are slow, which will be to do with the site you’ve build
  • the issues is on your side, such as a fire wall, or your ISP throttling the site.
Down detector isn’t that reliable. And I’m pretty sure it has problems with the anti bot system used here.
This is a community forum, not a helpdesk. There is no help desk. End of the day, we’ll help where we can, but you are the one responsible for your own site.
So Sorry, You Were Right !!
It Was Issue With My Shitty ISP “JioFiber“ And Also With The USB Tethering Issue Which Dropped Speed When Opening Something And Showed Full Speed Throttling While Speed Test
So Sorry For The Inconvenience,
But Thanks For Letting Me Check For The ISP Issues
@Admin Close This Issue
Avoid pinging the Admin, he’s annoyed by this
Closing this for you since you asked
