Agressive marketing
thats too match
Warning icon
You are seeing this message because ad or script blocking software is interfering with this page.
Disable any ad or script blocking software, then reload this page.
Would you like to give some details on this issue ?
I assume your on about the user panel and hope page on infinity free?
If so, the adds are there to pay for the service, and are what keep infinity free… free. I understand its frustrating, I use an add blocker 99% of the time too. But its the price we pay for a free service.
i’m sure you’ve heard the saying that nothing is free in life.
So are you using an ad blocker or script blocker? If so, then everything is working at intended.
Please understand that we provide a completely free service, and are mainly dependent on ads to generate revenue. If you then block those ads, we’re spending money on you, but you’re giving us nothing in return.
If you consider it “aggressive” that we take action when people deliberately take away the main income stream that makes this service possible, then that’s your opinion. I think it’s a necessary step to preserve the viability of the service.
If you are using an AdBlocker, and it has the ability to exclude blocking certain websites, add:
!http://dash.infinityfree.com
!http://forum.infinityfree.com
!http://infinityfree.com
[You may or may not have to add its HTTPS counterparts, it depends on the AdBlocker]
EDIT: Don’t include !, that was used to not display OneBoxes in this post.
