I’M ALLWAYS GETTIN THESE ERRORS AFTER IMPORTING A NEW STARTER TEMPLATE OR INTALLING PLUGINS
Import Customizer Settings Failed!
WordPress debug mode is currently enabled on your website. This has interrupted the import process…
Kindly disable debug mode and try importing Starter Template again.
You can add the following code into the wp-config.php file to disable debug mode.
define(‘WP_DEBUG’, false);`
I got this message when I try importing a starter template on my astra theme.
i tried what it it says to do which is to add the following code [define(‘WP_DEBUG’, false);] into the wp-config.php file.
which I did but the error kept coming
I would be very concerned if my software would refuse to work with debug settings enabled. Showing a warning saying to be careful with enabling debug settings in production, but simply refusing to work? How would you debug the import then?
With Debub Disabled i would get stuck or give me the same message:
You can add the following code into the wp-config.php file to disable debug mode. define('WP_DEBUG', false);
At this point i don’t know what to do i followed some videos on youtube on how to solve the problem, nothink helped. i can give you my credential to seek for yourself too, cause i am constantly into this problem since i got my domain hosted from you guis. its been already 1 week or more
